Old 02-13-2015, 09:36 AM
zack11122 zack11122 is offline
Two grounds on the intake manifold and two grounds on the driver side of the head. All are on.
Ecu is plugged all the way in. I'll pull my distributor and do the 360 and see where that leaves me.
Sent from my iPhone using Tapatalk
Old 02-13-2015, 11:36 AM
josh_s13 josh_s13 is offline
If the timing chain matches up with both cams and the crank and the distributor point at #1 (or maybe a hair past) I wouldn't think that you would have cam and distributor 180 degree out of phase problem.
Old 02-13-2015, 01:09 PM
you wouldn't think so, but I've swapped a handful of dizzy engines and probably 80% of the time I have to pull the dizzy and turn the engine over once.
Old 02-13-2015, 01:38 PM
I usually pull spark plug number 1 and rotate the engine with my thumb over the spark plug hole to make sure that I am on the compression stroke.
Old 02-14-2015, 04:03 PM
When I let off cranking it fires once or twice. That indicates I'm on the exhaust stroke correct?
Old 02-14-2015, 04:55 PM
Well. Distributor was off. Got it running. Got warm. And it I shut it off. Now it won't start. My luck.
Old 02-14-2015, 05:17 PM
Engine codes?
Old 02-14-2015, 05:19 PM
Didn't even think to check. I will soon.
Old 02-14-2015, 05:59 PM
Okay. So I'm running codes 12(maf?) and 34(knock) I'm not sure why it's throwing the knock code. It's brand new. And I'm not sure if it still is. My first start up was without the maf hooked up. I need to reset the ecu. But those are the 2 codes I pulled
Old 02-14-2015, 07:23 PM
I wouldnt think either of those would inhibit cranking up. Could the distruibtor have rotated within it's adjustment slots? The range of ignition timing an engine can run with is greater than the range it can crank from. At least this has seemed to be my experience. Just a guess.
