Go Back   Nissan Road Racing Forums > Engine > Forced Induction
  #11
Old 11-03-2017, 08:43 AM
RalliartRsX RalliartRsX is online now
Originally Posted by PoorMans180SX View Post
Keep in mind that is the new 60mm wheel va the GenII 67mm wheel. Quite an improvement if you ask me.
Check out the 3d printed concepts on the raptor engine, the new turbine housings are very EFR-esque. Speaking of which, I’m sure they’re feeling the popularity of the efr range, and it was only a matter of time before they responded. I’m excited for some competition, because we’re going to benefit!
Atleast quote my entire post for proper context lol
Bench racing/paper racing is good for about 30% of real life results. I will come to final judgement once I see this turbo on a real VET (or whatever) doing big things. Bench racing with MAPS is one thing, area under the curve, response, etc is where it's at for everything outside of drag racing, which no amount of flow maps can properly characterize.
EFR is a perfect example of this (remember, they had to up the HP limit as it turns out, they flowed a ton more than originally advertised).
However, as I stated, just like how the EFR was downplayed because of flow maps, Garrett may be on to something here once these hit the streets.
What's good for the goose, may also be good for the gander in this case. Garrett is very capable to making big things happen
  #12
Old 11-03-2017, 08:48 AM
Def Def is online now
You can make crazy power running a turbo way off the compressor map, but that sort of usage only works for a hard-parking street car or drag racing. Anything more and it will not prove reliable for either the turbo or the engine most likely as your IATs will go through the roof as your intercooler saturates.
That is impressive flow for a 60 mm turbo, but unless there's a huge leap forward on the turbine side, it's going to be tough to utilize all that compressor flow.
'03 Honda S2000 - pretty much stock
'11 BMW X5 35i
  #13
Old 11-03-2017, 11:15 AM
PoorMans180SX PoorMans180SX is offline
Send a message via AIM to PoorMans180SX
Wait, what needed more context? We’re having a discussion and I’m posting up flow charts that are a good indication of performance given they’re generated by the same company. I’m not claiming any kind of results, just interested in comparing to what’s currently available.
^this. I’ve worked with Evo dudes for 6 years, in shops that have dyno’s and specialize in tuning them. Evo dudes love big power numbers, and will run whatever they have to to get them. Then they street drive and go to two drag nights a year.
Are the results impressive? Sure, but they’re also not ideal.
The turbine map says it flows about 5-6 more lb/min than the 2867 in the biggest housing. From what I understand, a more efficient compressor also makes the turbine work less. It should definitely be interesting to see what they’ve come up with here.
Support innovation, buy from companies that design their own parts!
Friends don't let friends buy knock-offs.
Suspension before power.
  #14
Old 11-03-2017, 06:01 PM
croustibat croustibat is online now
Well, prices are out and my expectations were short lived. 2K$ for a non proven turbo design that requires a new elbow, downpipe, hotpipe and header ? And i still need to add the turbine flange and the wastegate ?
Please, someone sell me a 2867 A/R .64 with a T25 flange. There HAS to be someone willing to sell his to get a G25
Seriously, that price tag is higher than EFRs. I cannot see anyone switching to them unless they are desperate about packaging (EFRs are big) or rich garrett fans. Or if these turbos blow EFR where they clearly are better (mainly response)
  #15
Old 11-07-2017, 04:20 PM
As with EFR's, the price will come down a little with demand.
http://www.motoiq.com/MagazineArticl...ochargers.aspx
  #16
Old 01-23-2018, 09:16 AM
So, upping this since i will surely go G25 550 for my setup.
Do you know a place that actually has .72 AR IWG for sale ?
  #17
Old 01-23-2018, 11:16 AM
Has the pricing dropped croustibat??
  #18
Old 01-23-2018, 02:19 PM
induetime induetime is offline
Turbos Direct is local to me & one of the larger Garrett authorized dealers. I can get a quote for you if you want?
First 300ZX to break 500whp on the Stock Turbo/Stock Long Block, boost only, no meth.
Currently building sub-2800# 300zx Twin BW 6258 EFR, AMB Aero, TA-U & Road Race Car.
  #19
Old 02-11-2018, 06:44 AM
Hi, thanks for the offer, i did not see it until now.
They seemed not available but a few days ago I saw fullrace put a price on their website, so my usual sellers might have them.
If it is not too much of a bother I' like to. Remember I live in France, so no VAT and international shipping. Thanks
  #20
Old 02-13-2018, 01:35 PM
I talked to Turbos Direct & they only have the external waste gate housing in currently. When they get the IWG ones I will be stopping by to take a look my self & I will see what they go for.
