Old 08-31-2015, 08:45 AM
D K D K is offline
Default 350 knockback issues
Hello
I know ther are a lot of cars with serious knockback problems.
Has anyone found a good solution to fix the problem?
David
Old 08-31-2015, 09:22 AM
pump the brake pedal a couple times before stopping.
My G35 w/ StopTechs has had an annoying knockback issue since the day I bought it. poor design on the wheel bearings I guess.
Old 08-31-2015, 09:42 AM
gills gills is offline
Originally Posted by D K View Post
Hello
David
I had this issue on my 04 Subaru STi with the older 5x100 hubs/bearings. It sucks. I would just tap the pedal a couple times on the straights before braking zones like Matt93SE said.
You can also try this solution. Don't have firsthand experience with it though:
http://www.apracing.com/Info.aspx?In...10&ProductID=7
Old 08-31-2015, 03:36 PM
icantdrift icantdrift is offline
A residual pressure valve will also help some, but if your bearings/rotors are sloppy you will still have it happen.
Old 08-31-2015, 07:52 PM
G35/350Zs just do that - the bearing is underdesigned for the loads. Nothing will really fix it except a more robust bearing/spindle.
Old 08-31-2015, 09:03 PM
theultimatehero theultimatehero is offline
I had no idea what this meant, nor that it had a specific name. For anyone that needs an explenation (like I did) StopTech has an article on it. I have found other usefull articles on their site too, like this one on Warped Brake Discs.
Old 09-01-2015, 08:47 AM
Right knee injuries are great practice for left foot braking.
Old 09-01-2015, 06:51 PM
eye-5 eye-5 is offline
I've seen some cool in car footage with pros that always tap the brake with their left foot before any major braking zone.
Sent from my SGH-M919 using Tapatalk
Old 09-02-2015, 06:47 AM
There's a damn good reason for that..
Old 09-02-2015, 08:26 AM
I do it before every corner except for corners that are immediately after the previous. It's a great safety habit to get into. It firms up the pedal from knockback plus will also warn you early if there is a major issue.
Certain cars are more susceptible than others but the severity and occurrence is also track dependent. Tracks with taller curbs and tracks where the fast line is using those curbs will increase both occurrence and severity.
My lap around Mid-OH. The light above the shifter is connected to the brake switch - https://vimeo.com/108166468
