Go Back   Nissan Road Racing Forums > Classifieds > For Sale
Old 11-20-2017, 09:26 AM
Matt93SE Matt93SE is online now
Default 1996 240SX Road Race car for sale (Houston, TX area)
I bought this car in 2002 as a street car, and have built it into a regionally competitive SCCA Club Race car.
However, I've since bought an RX7 and the agreement with the wife was than when I got the RX7 on track and running well, the 240 has to go.. so here we are.
Brief history of the car:
Purchased in 2002 with clean title, blown engine @ 90k miles.
Put a 70k mi engine in the car (mileage verified- helped the guy pull it for an SR swap), and drove the car daily for ~3 years. Eventually, it turned into a track-only car and in 2009-2010 I caged it to go racing.
Since 2010, car has run ~45 SCCA sprint races and finished every race. Has also run a gazillion DEs, SCCA and WRL enduros, and various non-SCCA local races. Stone-cold reliable. NEVER A DNF!! It's not terribly fast overall, but I finish better than a lot of faster cars because I actually finish!
Many SCCA National/ Majors wins, several 2nd and 3rd place finishes.
Lap times for comparison for the local guys:
MSR-Houston: 1:47 both directions
TX World Speedway: 1:59
TX Motor Speedway: 1:39
Eagle's Canyon: 2:11
Harris Hill: 1:32
Hallett: 1:28
Sebring Long: 2:36 (back when car was in street trim on street tires. Drove car to/from Houston to Sebring)
The car is listed first, spares are listed separately. Car buyer gets first chance at the spares, and I'm not pulling any parts from the list until the car buyer chooses to take or leave them.
The car: 1996 240SX
~140,000 miles on chassis
SCCA logbook- current annual good
6pt roll cage by Greg Lucas, Lucas Racing & Restoration in Houston.
AMB hardwired transponder
ESS fire system, 5L bottle. 1 circuit/nozzle on driver, 1 circuit, 2 nozzles in engine bay.
Kirkey Intermediate Road Race Seat 16” width I think (can get part number off seat)
Schroth FIA-spec 6-pt harness- good through Dec 2018
Removable drop-in windows. (car can be stored outside)
Longacre Racing alu steering wheel, quick release hub.
New battery 11/2017, located in trunk
Autometer Phantom series electric Water temp & oil pressure gauges
APR GTC-200 48” SCCA-spec wing
NASCAR splitter w/ alu undertray
Suspension
KTS coilovers
5 lug hubs
Z32 rear uprights, spherical shock mounts
aftermarket RUCAs
stock rear toe, traction, LCA w/ Mazdacomp sphericals
SPL rear subframe collars
10mm H&R hubcentric wheel spacers
Sus Tech front sway bar, ends made adjustable
Sus Tech rear sway bar (not installed currently)
Brakes
Wilwood brake/clutch pedal assembly. 5/8” clutch, 3/4” and 7/8” brake MCs
wilwood bias adjuster knob for pedal assy
2-pc front rotors, 11.7” x 1.25” Coleman discs (R32 GTR size)
Wilwood Forged Superlite 4 piston fronts
Z32 rear brakes. will include spare uprights and Superlite calipers for 2-pc rear brakes.
Drivetrain
New transmission mount
4.08 Z32 VLSD installed w/ finned rear cover
ACT clutch
Fidanza aluminum flywheel
Engine
A/C and power steering delete
ASP crank pulley
S13 248/248 cams
Injen intake, K&N filter
NGK Plug Wires
1qt oil catch can
14” electric fan (clutch fan delete)
Hotshot header (NLA- hard to find!)
2.5” exhaust, Moroso Spiral Flow muffler
Over $15k invested in the car. Asking price $7000.
Spares
transmission- 2nd & 3rd synchros worn
transmission- good synchros, but missed a shift and now reverse won't engage. (both transmissions good enough to get you through a weekend)
4.3 Helical LSD
4.08 open- 5 bolt VLSD stubs
3.9 Viscous LSD- 5 bolt stubs
5-bolt J30 axles. Need cleaned & rebuilt
stock spoiler
Z32 uprights- spherical shock mount, stock bushings
Z32 uprights- no bushings, sandblasted clean, began modifications to fit Superlites in the rear.
Wilwood Forged Superlite calipers, 1.39” pistons. NIB
Hawk DTC60 pads, NIB, fit superlite w/ bridge bolt
Hawk DTC70 pads, NIB, fit superlite w/ bridge bolt
Raybestos ST47 pads, NIB, fit Superlite w/ bridge bolt
Godspeed FLCAs modified w/ sway bar mount & US bearings
Godspeed RLCAs- new unmodified
Tie rod relocation kit
Engine mounts, 2 sets- 1 new, 1 lightly used
SPL tie rod studs
Autometer Oil Temp gauge, #5747
Spare rotor hats (used)
also have 12.6" rotors and hats, no mounting brackets.
Autronic SMC ECU. Tuned for SR20DET. Incl trigger wheel for SR and KA, programming cable, software, manual, harness stub.
Aerocatch hood latches 3038-001. NIB
95 5MT ECU w/ uncut harness
Z32 rear street pads- 1 set OEM, 1 set “Parts Store grade”
ARP 100-7717 “EVO” wheel studs. Card of 5- BNIB
Stock rear S14 suspension arms. 1 ½ sets
Z32-NA rear subframe
17x8 Racing Hart CP-035R, 9pcs (4 currently on car)
17x8 5Zigen FN01R-C, 7pcs
17x8 MB Comp, 4pcs
16” S14 SE wheels, 4pcs
Approx $7,000 value of all spares. Asking $10,000 for car with all spares, or $5,000 for spares separately. Will not sell spares before car is sold.
contact: matt_at_mattblehm_dot_com
2012 pics: The front splitter and air dam has been rebuilt since these photos, and it's all black now...
Originally Posted by SoSideways View Post
Old 11-20-2017, 01:32 PM
gills gills is online now
Bravo!!
CLICK HERE for Wilwood FSL6R Radial Bracket & Rear Wilwood BBK GROUP BUY
S14 VQ AER Endurance Racing Team
Old 11-21-2017, 07:52 AM
Yeah I had it around somewhere, just not sure if I ever bothered putting it up for sale here... not exactly the market, ya know? (most everyone here already has a car- why would they want another one?!)
Old 11-21-2017, 09:23 AM
I hear you. I like to post as many places as possible. You gotta whore it out!
I ended up selling my S13 endurance racer through Craigslist of all places.
GLWS
...oh, I'll buy that splitter if you want to pull it off
Old 11-22-2017, 03:50 AM
Hardrvin Hardrvin is offline
Because we are here to help other friends make bad decisions.
"Get into road racing, it'll be cheap, and your wife will be OK with it..."
Old 11-22-2017, 05:36 AM
My wife let me build this car with her full support!
And it's the cheapest running cost of any race car I've owned so far... so there's that...
