Old 11-15-2008, 09:50 AM
No Rotr No Rotr is offline
Send a message via AIM to No Rotr
Default LS1 vs VQ35
So I bought my 240 with full intentions of instantly pulling the SR20det thats currently in the car. I am torn between two engine to stick in the car though. The two options area stock LS1 backed by a T56(from a GTO with the better gear ratios) or a VQ35 backed by the 350z/g35 6-speed. Once the chassis and suspension are sorted out, I will want more power. That means a cam for the LS1 and boost for the VQ. Both engines weigh about the same, but because the VQ is shorter, it would result in a better weight distribution. The VQ requires more work and more fabrication, but thats the fun part. I know myself and I think if I did the LS1 I would be bored with it and end up making too much power for the cars good. Price wouldn't be very different between the two once more power is made. Ive done the LS1 and something new would be nice. Lots of power isn't necessary on track, but it sure makes for lots of fun on the street. The VQ swap isn't very common and because of that you can't just buy some parts and throw it in like you can with a LS1. What would you guys do, and keeping the SR isn't an option, I want something different. Thanks
-Dave
Old 11-15-2008, 09:59 AM
jmauld jmauld is offline
I went through this a few months ago and I stayed away form the VQ35 due to the amount of effort needed to get the engine management to work. The VQ would likely be the cheaper option if they took care of that issue.
Old 11-15-2008, 10:43 AM
a_ahmed a_ahmed is offline
Awesomeness with the VQ:
http://www.youtube.com/watch?v=APVz_4rjPIg
But its more driver than anything else making full use of that car. I would like to know more about it though . Seems mega awesome.
The sound is also quite brilliant.
The LS1/and its many variants 2,3,6,7, etc... are appealing as... they are power monsters, easy to mod, NA, turbo brings stupendous power. The initial cost is alot but the long term cost is little and worthwhile. Reliable, good on gas (lol), power anywhere in the power band, low-end, mid-end, high-end. Proven to be swappable and worthwhile in so many different chassis. What can one say. Simple design, pushrod, low center of gravity. YOU CAN make it 50:50 with cutting firewall/some extra work. So... yeah...
It's a personal choice.
The VQ is the lightest engine choice if im not mistaken to put in an s13.... the LS is like 100lbs heavier? T56 = awesome. 350z transmission = awesome but not as much methinks (i dont have facts to back me up, but makes sense to me, more torque, more requirment no?)
Both seem awesome in different ways... but going all out me would think LS would be the right choice... but power and speed cost money as does everything in this hobby... so meh..
That VQ is sexy thoughh.
Old 11-15-2008, 12:14 PM
the ls1/t56 is 50lbs at most heavier than the VQ if even that. There is a EMS solution for the VQ35 out as well. LS1's are great, but their oiling systems are not. And with large r-comps and the higher rpm I want to run with a built motor down the road a dry sump system is necessary. The VQ would just leave me wanting more power I think.
Old 11-15-2008, 12:21 PM
Sikky's LS swap kit for s chassis and z chassis looks awesome, includes a race oil pan and some other bling, and has some oil starvation sorted out with the lil accusump system
http://www.thermalnator.com/products.../nissan_mounts
http://www.thermalnator.com/products...parts/accusump
I like their kit looks like an overall high quality product.
As always I'm lke everyone else a cheap broke ass s chassis owner who wishes it was less expensive but you get what you pay for haha. I won't be spending no money on the car in quite some time heh... but this is what I wish i'd get and do.
And the vette with the right exhaust sounds menacingly awesome:
http://www.youtube.com/watch?v=CZPBRjcDN4Y
http://www.youtube.com/watch?v=dPQfzjkYe3U
http://www.youtube.com/watch?v=3SdKoWbtcyU
Bottom line is, I wish I had a corvette to build and not a 240sx lmao.
Old 11-15-2008, 12:46 PM
That's only true if you're talking about the stock LS1 from a camaro. The LS6 in the vette has no oil problems. There has also been no reports of those oil problems when using the GTO oil pan. However, there are a lot less people taking GTOs on track as opposed to camaros and vettes.
But effectively, upgrading the oil pump to a LS6 oil pump and changing to the GTO oilpan, seems to cure the oiling issues with the camaro LS1.
Old 11-15-2008, 01:28 PM
I think it'd really depend on how much power you want. If you just want about 300 rwhp, the VQ would probably be my choice(what about a VH45DE?), but if you want much beyond that then I'd go with an LS something if that was the only other choice.
Old 11-15-2008, 03:45 PM
turtl631 turtl631 is offline
I think for the cost of having a really nice LS engine setup, I'd rather just buy a C5 and not have to deal with the jankiness of a swap. It'd make for a nicer street car, and what kind of racing would let you run a Chevy V8 in a nissan?
Old 11-15-2008, 04:05 PM
I'm inclined to agree, you can get a Z51 C5 and haul ass relative to just getting a V8 into an S chassis.
The VH45DE doesn't look that bad if you do a good bit of work yourself though, and would be fun.
Old 11-15-2008, 04:58 PM
ecugrad ecugrad is offline
I know a guy who is on motor #3 from the crappy oil system in a 350z.
What about the 5.3 all alum Chevy truck motor as the low cost leader.
