Old 06-13-2015, 11:21 AM
rioredstang rioredstang is offline
Default machining the deck?
Ok. I have mocked up my new motor and started checking clearances. The piston is about .110 down. How much can you take off safely? Seems like .100 is alot to remove.
Old 06-13-2015, 12:04 PM
You have to account for rod/piston stretch as well as thermal growth. 0.010" of piston recess sounds reasonable with a 1.1 mm compressed headgasket, but at high RPM maybe it's an issue.
The 0.110" recess sounds odd though. I don't recall seeing anything remotely close to that in my SR bottom end.
What's the story on your build?
Old 06-13-2015, 01:27 PM
Ka24de
Carillo rods-BC crank-JE pistons
Old 06-13-2015, 07:41 PM
It honestly sounds like a bit of a stackup problem to me.
I would cc the head and the piston dome + recess, then calculate your CR with a normal HG. I'm betting it's way out of spec...
Old 06-14-2015, 01:05 PM
Is it safe to remove that much from the block. I worry about timing problems
Old 06-14-2015, 09:19 PM
That is a lot to remove. Service limit is a fraction of a millimeter IIRC.
Old 06-15-2015, 07:13 AM
I wonder if the pistons you bought were some lower CR ones for turbo applications, or the pin height is wrong? That just doesn't sound right for an NA build..
Old 06-15-2015, 08:11 AM
It sounds to me like something if off as well, that's why I suggested measuring actual CR vs. advertised. I'm betting either the wrist pin height or rod length is off for the crank stroke.
Old 06-15-2015, 12:10 PM
Aftermarket rods, crank, & pistons.. so you never know.. might measure complete stroke while you're at it to see where things are. does the BC crank have shorter stroke? stock rod length?
Old 06-15-2015, 04:18 PM
I think it's a longer stroke that can get you like 2.5-2.6L.
