Old 08-16-2011, 12:46 PM
Bluerb240 Bluerb240 is offline
The factory pump is pretty strong as it is. if u keep the revs under 10k it should be fine. The most I rev mine too is 9300rpm when I'm flogging the crap out of it.
Old 08-16-2011, 01:26 PM
RallyBob RallyBob is offline
I'm more worried about the cornering forces and oil starvation. Most SR's have great oil pressure...right until the pump gets starved.
Old 08-16-2011, 02:19 PM
Have you thought about a crank scraper and windage tray? I ran one of these on my T28 powered B13 sentra as I was afraid with the fresh hoosiers, suspension, and the nismo LSD that I'd have an oil starvation problem with a few of the tracks I ran.
Never had an oiling issue in the 5+ years I tracked B13's.
Old 08-16-2011, 02:52 PM
Default ......................
You can try and contact Mike Kojima @ motorIQ. He might be able to give some more info too on this topic.
Old 08-16-2011, 03:06 PM
I've just seen too many blown up SR's over the years to want to risk the one in this car. Too many pricey internal parts. And with 275/35-15 Hoosiers on all 4 corners and full aero, I'm just being particularly cautious.
Old 08-16-2011, 03:07 PM
I'm not sure if Mike has dry sumped anything SR, but I think I still have his email. I will contact him, thanks for the reminder.
Old 08-16-2011, 05:00 PM
PerilousActs PerilousActs is offline
NRR Sponsor
Send a message via AIM to PerilousActs
Link to the thread regarding the engine on the previous page?
Old 08-16-2011, 05:13 PM
I can link you but not much info was given. The guy makes a few post everyone once in a while. English is his 2nd language he is from Peru.
http://www.sr20-forum.com/vvl/39642-...0ve-itbss.html
http://www.sr20-forum.com/vvl/45943-...yno-sheet.html
http://www.sr20-forum.com/vvl/48013-...-p10-peru.html
enjoy.
Old 08-16-2011, 07:19 PM
what about just using a 3qt Accusump? works for a ton of road racers.
Old 08-16-2011, 08:07 PM
Accusump will work. You can always make some baffles around the pickup and maybe extend the pan out a bit more to give more time as the oil flows against the baffles/gets sucked up.
