Old 01-11-2011, 07:19 PM
Big J Big J is offline
Default 2JRacing 200sx new track build
We've, Joe Ippolito and myself, have been running a 2002 SE-R in NASA Time Trials since about 2008. Joe Ippolito ran it in SCCA the year before. I came on mid 2009 to tweak some more out of the car. At the time Joe already held track records at most of the tracks in the Southeast. After some minor chassis and suspension tweaking we pushed most of the track records 3-4 seconds deeper. Those TTE records should stand for quite a while. 2009 we won a NASA National Championship in TTE by a margin of over 2 seconds. We loved the 2.5, but we needed a little more, and despite my comfort zone with turbocharged QR25's we went a different route. You really can't rev a QR high enough for a real road race car once you take it to a certain level.
We decided to swap a Maxima VQ35DE into the Sentra chassis in the off season. We took our time and even though we missed the first several races of the season still managed 3rd in points in the region and never finished lower than 3rd on a race weekend. We ended up wiring it up to run off of a 350Z ECU so we could take advantage of the better base tuning, and to take advantage of tuning and compatibility with UpRev's Osiris software. The Sentra will be back for next season (2011) with a few areas addressed we didn't find the time to do last season. Mainly weight distribution, a little more track width, and the addition of a full cage..... we've really pushed the chassis past the pick kids up and go to the grocery store function it was designed for.
We (me mainly) got a little frustrated dealing with the classed rules of the TTF-TTA levels, so I decided we needed to do an unlimited build for 2012. Since we're Nissan dedicated, and even worse, FWD junkies, we only had a few viable options.
The B13 is was a good candidate, but we already have one and run it in Lemons, and, hate me if you will, I'm not a big SR20 fan....... I ran through the Nissan line up (and considered the budget) an found a deal on Craig's List for a 1995 200SX SE-R with some slight fire damage to the steering column due to an amateur wiring job. So $500 got landed us a great car.
Same wheel base and track width as our current 2002 SE-R, but, it's 7 inches shorter in length (think lower polar moment of inertia), about 400lbs lighter from the get go, 1 inch shorter, great windshield angle, and it's a 2 door, which gives plenty of room to mod the fenders for big tires, and more room for my fat ass to climb in and out.
The basic plan is to get the car with cage down to 2000lbs, maybe less. 949 6UL 15x9 wheels, 275/35/15 Hoosiers, Brian at Fastbrakes to work some magic on a brake setup, manual steering conversion, VQ35DE and possibly hybrid w/ revup heads, a 350Z ECU (revup if we go with a hybrid) with UpRev Osiris, 6 speed LSD trans, wide fenders, lexan all around, flat bottom conversion, a good bit of aero, and somewhere around 290whp (hp/wt limits in TTS are the only real rules), spherical bearings in place of bushings, 4-5" of track width, BC racing coilovers, and whatever else I think it needs.
Currently the car is a stripped out shell over at Northpoint Automotive getting a cage.
ETA on completion for the car is sometime in 2011 to run in the 2012 season.
The only pics I have are of a stripped out, dirty, shell.
Old 01-11-2011, 07:33 PM
veilside180sx veilside180sx is offline
Owner/Administrator
What does a VQ swap wind up costing you guys?
Old 01-11-2011, 08:25 PM
rule #5, never keep a running total, lol.
If you did it smart and didn't go crazy, don't pay for labor, and have some ok skills and equipment, 2-3k. Once you go into the motor, it goes up.
We don't need A/C, any factory creature comforts, solid mounts are fine, etc. so we don't sweat that kind of stuff. We have Osiris tuner already, so for the cost of a license and an e-bay or 350zforum ECU, we pretty much have a standalone. Harnesses are around $200-400, axles, LSD trans $250-450, VQ bell housing $2ooish, cable shifter assembly (I'm using a Mitsu EVO MR 6 speed cable unit for this one....quality) $45 on the EVO forums, B15 spindles $50 at a salvage yard, used FWD VQ $500-900, and the list goes on.
You start building the motor and it goes up quick...... if I can do a revup head swap, I should get close to my power goals w/o going crazy.
Old 01-11-2011, 08:39 PM
VQ35 > SR20
The B13 might end up with a QR25 in it, we have all the stuff laying around.
Old 01-13-2011, 05:09 PM
2JRacing found an 06 Maxima VQ35 w/ 26k on it for $500. Going to pick it up tomorrow.
Old 01-13-2011, 06:13 PM
Owner/Administrator
LOL sweet price
Old 01-13-2011, 08:33 PM
That's a crackhead price. I've been checking out FWD VQ35 prices lately for a little project I'd like to start in the far future.
Old 01-13-2011, 09:55 PM
same salvage yard is has 6 up for sale for $500 a pop.... of course we want the one with 26,000 miles on it.
We're hoping they left most of the sensors on it.
Old 01-14-2011, 12:19 AM
I don't wanna be the one to ask the stupid question, but whats the RWD tax on a VQ these days?
Old 01-14-2011, 06:56 AM
way more than a FWD..... You can run a FWD on a RWD ECU and get the same performance. I'd go the FWD bolted to a RWD trans and RWD ECU route and save some $$$. plus, I think a modded FWD intake manifold out performs any RWD intake manifold.
