  #61
Old 03-25-2010, 08:26 PM
Full-Race Geoff Full-Race Geoff is offline
Default MOTON = omfg
oops
  #62
Old 03-25-2010, 11:49 PM
floodo1 floodo1 is offline
Originally Posted by Epstein View Post
Don't forget that where your ride height is set (and the subsequent 0 height) will affect your graph. The overall shape should be the same, though.
As far as the ziptied shorter traction arm theory, I really don't think bumpsteer has anything to do with it. With a short traction arm, the spindle rolls forward a lot quicker than with a longer one. That tells me that anti-squat is being changed. I really doubt the drift guys have bumpsteer issues anyways, considering the fact that they don't have any compliance to begin with. That's one way to solve bumpsteer.... don't have any bump.
anti-squat is determined by the location of the two inner pivots on the lower control arm. the traction arm doesn't change anti-squat.
  #63
Old 03-26-2010, 12:09 AM
yes, and the angle of the subframe is the easiest way to change the plane that the LCAs rotate on - or you could cut the lca tabs off and relocate like many do to S13 subframes to convert to s14
  #64
Old 03-29-2010, 06:28 PM
racepar1 racepar1 is offline
Excellent work! I am quite impressed. One thing though...
Did you play with the toe arm lengths at all???
That seems to be the only other thing to adjust without fabrication work.
function > form
1990 240sx fastback: IN PROGRESS
  #65
Old 03-29-2010, 06:33 PM
look at his 8.5" / 12.25" plot, it goes real nice from toe in, to 0 to toe in. This amount of toe in gain just means that epstein needs the toe arm shortened (since its behind the hub, it would need to be lengthened if in front of the hub) to get it just right.
->the toe arm is longer than it needs to be, so shorten the toe arm by moving the eccentric to the furthest position
  #66
Old 03-31-2010, 06:23 AM
TSL TSL is offline
I don't have anything constructive to add, other than to say this is an awesome thread and it is exactly this sort of thing that made me sign up to this forum.
I am just beginning to experiment with alignment settings and the data in this thread has given me an entirely new insight into the whole process.
Keep the data coming!
  #67
Old 04-05-2010, 02:59 PM
Thanks for the info! when I build my subframe I am going to weld washers onto it and eliminate the cam bolts altogether. I figure now that the geometry has been kinda figured out there isn't much need for adjustment once you position the mounts to the best of current knowledge.
function > form
  #68
Old 04-08-2010, 05:26 PM
Scores240 Scores240 is offline
Are these lengths measured from the centers of both bolt holes?
  #69
Old 04-09-2010, 07:04 PM
Yes. If they're in the car and the bolts face the same way, its easier to turn the heads to you get 2 parallel flat sides and measure that way. It's a hell of a lot more accurate than eyeballing bolt centers.
  #70
Old 04-09-2010, 10:15 PM
Yea i figured it out when i went outside to adjust everything. Hopefully its set up good enough for an autocross on sunday.
