Old 08-23-2009, 11:07 AM
veilside180sx veilside180sx is offline
Owner/Administrator
Default Wilwood Clearance Thread
I figured it would be a good idea to have a list here of the wheels that clear the Wilwood/Fastbrakes setup.
11.75"
ATS Comp Lite 15x7 +35
Pro Race 1.2 15x7 +35
Pro Race 1 15x7 +35
949 Racing 6UL 15x7 and 15x8
Volk TE37 15x7 +35
Enkei RS-Evolution 16x7 +35mm
11.00"
Enkei RP02
Rota C8
Rota Subzero
Rota Grid
Kosei K1 15x7 +38
Flunk list
The list is all for the 15" sizes.
Old 08-24-2009, 10:49 AM
Might be worth it to mention which wilwood calipers these are.
I know some of the kits come with Dynalite or Superlite calipers- not sure which application you're referring to.
Old 08-24-2009, 11:23 AM
Most all of the verifications above were done with dynalites... as this is the most common setup for the sentra guys for wilwood brake kits.
I did testing on the ATS's, TD 1.0, and TD 1.2's for this list on the SR20forum when I had a sentra and it was with billet dynalites. I miss all these wheels... cheap, light, and durable.
Old 08-24-2009, 11:54 AM
Otay.. In that case, throw 16x7 +35mm Enkei RS-Evolution in the pile for fitting 11.75" rotors. It's got a mm or 2 to spare, but that's about it.
Old 08-24-2009, 07:39 PM
Owner/Administrator
Added
Old 08-24-2009, 07:57 PM
Cory Cory is offline
I will assume you already did this, but if not, watch closely for any contact. I have heard of rims being sawed in half from heat expansion under hard lapping.
Cory B.
"Driving a race car as fast as possible is all about maintaining the highest possible acceleration level in the appropriate direction."
http://www.youtube.com/user/nissanfanatic240
Old 08-24-2009, 09:56 PM
I'm using bigger wheels now, but thanks.
Fortunately, where the wheels were close to hitting was a part of the clamping assembly and had plenty of room to 'self-clearance' with the caliper.
