Go Back   Nissan Road Racing Forums > Engine > Naturally Aspirated
Old 10-19-2013, 01:48 PM
gbeaty gbeaty is offline
Default KA24DE main & rod bearing clearances?
What #s have people had good luck with? This is for an endurance motor.
Our crank has been polished and the rods have been honed, so I'm not sure if the original grade markings will produce consistent clearances. I'll know once I get everything measured.
Flatout Racing
#23 Z32 Chumpcar
Old 10-20-2013, 09:09 AM
Def Def is offline
I'd lean towards the upper end of stock clearance. Something like 15-20 ten thou rod and 18-24 ten thou mains.
'03 Honda S2000 - pretty much stock
'11 BMW X5 35i
Old 10-22-2013, 07:50 PM
rioredstang rioredstang is offline
I use the coated bearings from Calico. I would also coat the piston skirts. There are several types of coatings you can apply yourself. Techline Coatings is a very good supplier for these.
Old 10-23-2013, 12:53 PM
Tower240sx Tower240sx is offline
Resident Grouch
go with the standard recommendation of .001 of clearance per inch of bearing diameter and run 15-40 or so oil in it...the good stuff...rotella...
and no, none of that is sarcasm.
