Go Back   Nissan Road Racing Forums > Management > Announcements
Old 04-28-2012, 01:21 PM
tonto tonto is offline
Default ve section?
can we haz ve section?
as soon as i find a head, i'll be assembling parts and pondering:
o oil pump/crank pulley machining
o timing chain tensioner options
o intake mani & fuel rails
o selenoids (mechanical and electrical)
o exhaust mani options
o cams/springs/piston design vs rpm limits
o ecu tuning for injector timing/spark timing/fuel maps vs cam switchover points
quite a list, and since nrr basks in the glory of going their own way, i thought i would throw the idea out there.
Old 04-29-2012, 06:19 PM
Seconded. All the cool kids are doing it!
Old 04-30-2012, 06:43 AM
BEXE BEXE is offline
thirded, I want a setup for 9,000rpm
Old 04-30-2012, 09:47 AM
konjiki7 konjiki7 is offline
There are already some good post on this stuff scattered around NRR. Getting these into one area would make this the place to be for this swap/conversion.
Still Got a few part left! Shoot me a PM if you have questions!
http://www.nissanroadracing.com/showthread.php?t=5286
Old 04-30-2012, 11:35 AM
Tensioner is the same as near as I can tell...they mount to the same pattern and operate identically,
Crank Pulley needs 5mm machined off to use DE pulley w/ VE oil pump.
Old 04-30-2012, 12:35 PM
There are two types of tensioner's. The older sr20det/de type and s14/ve type. My ve and s14 tensioner had the same part number.
13070-2J203 - this is know as an upgrade for all older sr20's
Old 04-30-2012, 06:17 PM
Bluerb240 Bluerb240 is offline
The N1 tensioner is a little different than the normal. let me find my pics.
The only real difference I could tell was the flange was thinner vs the roller rocker SR20DE tensioner I had in my VE at the time.
Old 05-01-2012, 03:51 AM
I think that's the late model tensioner all SRs can use.
Old 05-01-2012, 07:54 AM
Beejis60 Beejis60 is offline
I wanna go 9k rpms....
on my LS
Old 05-01-2012, 08:43 AM
that's the buckets o' money strategy ^^^
you'll need about a 3" stroke and some serious pushrods, but the old man built a 318 pontiac they used to shift at 10K so you can do it if you like, for a shift or 2
