Go Back   Nissan Road Racing Forums > Suspension > Shocks/Struts (Dampers)
  #81
Old 06-03-2016, 03:35 PM
gills gills is online now
Anyone else have any updates they'd like to share?
I'm very interested in pursuing something custom/different than the Koni 861X route and the robustness of the Bilsteins has me intrigued....
  #82
Old 06-23-2016, 12:15 PM
.....crickets....
  #83
Old 06-23-2016, 04:51 PM
eage8 eage8 is offline
Mine are still working great
'89 RX-7 TurboII - SSM - Widebody - Ford 8.8 IRS - giant wing - Megasquirt3
'89 Corolla SR5 - SMF - 4A-GE 20 Valve 6 speed swap - Megasquirt-2
'01 Impreza 2.5RS - Rallycross Stock AWD / Daily
'81 BMW R65
  #84
Old 08-05-2017, 10:34 AM
Beejis60 Beejis60 is offline
I know I'm late here but how did you install them? I imagine you posted somewhere in here?
  #85
Old 08-06-2017, 07:17 PM
RallyBob RallyBob is offline
I built a set for a friend's B13 Sentra. Working very well so far.
Some pics in this thread:
http://nissanroadracing.com/showthre...?t=5457&page=2
  #86
Old 11-20-2017, 03:17 PM
turtl631's Avatar
turtl631 turtl631 is offline
Copycat
Send a message via AIM to turtl631
Im trying to get a friend to pick up an s13 for rallycrossing and ice racing. Anyone ever build a set of these for such a car?
~1992 240SX, SR20/Koni track day car
~2016 M3, daily driver
  #87
Old 12-21-2017, 10:19 PM
Umai Kakudo Umai Kakudo is offline
Default RE: S13 rallyx suspension
Contact JVAB in Seattle and get these.
JVAB Imports
2007 S. 126th St.
Seattle, WA 98168
+1 206 431 9696
janvanvurpa@f4.ca
http://www.rallyrace.net/jvab/
They are the best bang for the buck and made to be indestructible. He has them custom valved to your setup and can get Bilstien goodies from the old country that the USA office won't deal with.
I did a RallyX down in the Oregon gravel pit and did a tarmac drift day with a set of these dampers installed on a fully sorted stage rally Murker X4Ti. They are awesome, can bomb through anything, and did well on tarmac as well (got to be patient for the weight to transfer with all that extra travel!)
Might be overkill for ice racing. A Koni twin tube in S13 OEM sized housings might be better for low traction surfaces vs the higher hysteresis of a gas mono-tube. Hell, bone stock suspension works perfectly on snow/ice.
More details here: http://www.rallyanarchy.com/phorum/read.php?3,56526
Car build threads (stage rally S13 - Started out on 3KGT Bilstein inserts in OEM housings which didn't work well and were destroyed the first season, then upgraded to the JVAB kit):
http://forums.nicoclub.com/official-...t-t457229.html
Look through the JVAB web site galleries for his other fab work.
http://www.rallyrace.net/jvab/spgm/
This is how he builds Bilstein Struts (doesn't use the kit in the original post and does it at a lower cost with much stronger and more serviceable housings. Costs for a full set of 4 dampers are usually around the $2400 range IIRC.
http://www.rallyrace.net/jvab/spgm/i...in_50mm_struts
50mm vs 40mm
[img][/img]
The Nerd shall inherit the podium for knowledge is power.
