  #551
Old 05-14-2015, 08:32 AM
I never went with more actually. So 1.625" of spacing. A little more might be possible, but it was close enough to the brake rotor for me to not mess with it.
  #552
Old 01-07-2016, 11:16 AM
Black R Black R is offline
Are these arms ok to start with?
https://www.amazon.com/gp/aw/d/B00TU...A1B71JHHQ2I7WS
I received an amazon gift certificate that will cover most of the cost...
1990 240sx - Aristo 2JZGTE, R154, GT37, Defsport Wilwood kit, KTS coilovers - daily driver
1991 civic si - B18C5 / toda / ATS / hytech - autox
2001 integra type R - Greddy td05-18g - garage queen
  #553
Old 01-07-2016, 11:26 AM
They're all pretty much the same thing as far as I can tell.
  #554
Old 02-10-2016, 05:05 AM
Ugh... spammer.
  #555
Old 06-27-2017, 07:28 AM
Hrm I'm getting around to doing this, but I think it's not for me...
The china bay arms I got on amazon don't seem to jive with my Tein tension rods - something will have to be modded extensively to mate the two.
But my biggest issue is the GKTECH roll center correction kit I'm using - it has steel inserts for the oem taper on the lca ballpoint.
Is there an ots shank with oem taper? (Long shot I know)
  #556
Old 06-27-2017, 08:09 PM
Scores240 Scores240 is online now
I don't think you need the GKTECH kit any longer if you're doing this lower control arm mod. It allows you to use spacers on the ball join with the bolt instead.
  #557
Old 06-28-2017, 09:17 AM
^ but what about the tie rod end?
Doesn't it need to be spaced up by the same amount so as to correct bump steer?
And that balljoint seems to be tapered as well.
At this time, my preference is to use the GKTECH kit because of the steering angle correction as well.
I think I can have a machinist friend help me out with some custom shanks, however, and maybe mod the Tein tension rods to accept bolts rather than the pressed in ones that are there now.
  #558
Old 06-28-2017, 10:37 AM
You would need SPL tie rod ends or something similar to be able to space them the same amount as the ball joint.
If you're going to stick with the gktech bracket you c can't do this mod to the lca.
Sent from my LG-D850 using Tapatalk
Tags
baller knockoff parts, lca, roll center
