Old 11-24-2009, 05:21 AM
V1A V1A is offline
Great write-up Def.
Did you find that you had to add more spacers to your tie-rod setup? If you do, and you’re out of adjustment on the shank, would it be reasonable to take the same approach there (drill out the taper and use a bolt)? From what I remember, there isn't a lot of material out on the tie-rod pickup.
Old 11-24-2009, 10:47 AM
I don't know if you missed this question or not, but it sort of has to do with V1A's question as well...
What would you use for spacers between the bottom of the spindle and the top of the bearing, once you run out of spacers that came with the kit?
Stack some 3/4" washers on top of the spacers?
Old 11-24-2009, 10:56 AM
V1A V1A is offline
^ Def listed a MMC part number for shimming washers if additional adjustment is needed.
MMC p/n: 94773A780
Old 11-24-2009, 11:59 AM
Originally Posted by V1A View Post
Great write-up Def.
I ended up going with SPL tie rod ends. I almost made my own and used a bolt, but at the end of the day I felt like making at least a little part of this project easier on myself.
I'm using all their adjustment shims, and things look pretty good angle wise for even a bit more spacing between the spindle and bearing. I'm sure if you really needed just a hair more you could probably get a hair more adjustment out of them.
Old 11-24-2009, 01:23 PM
MMC p/n: 94773A780
I just went back and re-read it, and it looks like he used that part underneath to space the bolt's head down.
For the top, might have to stack like $20 worth of washers lol
Old 11-24-2009, 01:40 PM
I actually cut a piece of 1" OD DOM tubing and faced each side in my lathe. The washers I linked to are about 0.060" thick, so to get the same spacing as I used you'd need about 7 above the bearing and about 4 below the bearing. So figure you'd want 3 packs of 10 just to have plenty of adjustment in addition to the Godspeed spacer.
Old 11-26-2009, 05:20 PM
...another thing to spend money on over winter. thanks
Old 11-27-2009, 04:11 AM
a_ahmed a_ahmed is online now
Meh not me (surprise)... just wish list :P... for now.
How about some quantified and qualified driving experiences on this new changed setup
Old 11-27-2009, 11:27 AM
I also took off my front sway bar at the same time and haven't put it back on since I'm still messing around with the S14 front bar(probably won't work since it hits my GReddy oil pan with just slight travel up).
Overall the roll without a front sway feels about the same as it did before, and it seems like the car transitions even quicker up front. From the seat of the pants feel, I'd say it feels worth it.
Old 11-27-2009, 11:31 AM
That's pretty impressive that it feels the same without swaybar as it did with swaybar but roll center adjusted.
Put the swaybar on and see how it goes.
Definitely worthwhile work you've done two thumbs up.
Tags
baller knockoff parts, lca, roll center
