Originally Posted by Your Mom
cylinder 4 is the iffy one, i know some of that oil is from the pcv valve cause i saw the oil line in the intake port but not sure about all of it.
is it possible that with a bad valve seal or guide that i could be pressurizing the crank that way? probably not. its probably detonation, oil doesn't really have that great of a octane rating. which might also explain the low power. there is some very slight scaring on the walls but nothing i can feel.
theres was just tons of oil coming out the catch can thou. like i had a blue rag over the output of the catch can to stop the oil from getting on the manifold and i had to replace the rag 3 times cause it was filled with oil. its bad. not a single bit on the dyno... hmmm stationary vs g's on a road course.. or real life vs dynojet....
maybe it was just the missing i was experiencing at the track. part throttle. full throttle was fine. bkr6e thou, forgot to get some 7e's before the track day. aem log didn't show anything horrible, maybe knock sensor is dieing.
fail, fail, and more failure. stay away from me it might be contagious!!!
the only positive thing is if it is the head it wasn't my fault.
If you have bad valve guides it'll pressurize the crank case under boost, then suck oil in while off throttle. I'd think on a dyno you won't be tossing quite enough oil around the head to really get a huge amount in there. Or maybe the guides just seal worse when they get hot.
If it's detonating you should see some tiny specs of aluminum on the spark plugs from eroding the piston.
