240sxTTC 2014 Build - Teaser Photos
  • 240sxTTC 2014 Build - Teaser Photos
    Some teaser photos of the winter build! Will start an official build thread once I get a little further along.
    NASA Time Trials TT3
    BTW I work for Garrett
    Are the fronts going to be that wide too?
    Thanks for the other info Rob. Might save me some money.
      Those are 3.5" flares?
        Lately, I've been thinking about what is the best way to get some "slider axis" angle up front. Extending the lower controls arms 1-2" and pushing the strut tops all the way inward should net you a decent moment arm length and decent camber gain.
        Since you have to fill up those massive fender flares, running a longer FLCA should not be a problem for you. High SAI does make adjusting bumpsteer an issue, but other then that, with the low steering angles that road racers and autocrossers use, I don't think it effects camber all that much.
        High slider axis with a custom +1-2" FLCA, should give you lots of room for a big tire, great scrub, decent camber recovery, above ground roll center... Seems like the benefits of high SAI, out weigh the negatives.
        Still have some testing left to do on my setup, and validation of camber loss/gain curves during suspension travel and steering. I'm sure there is still much more to learn!
          Also what's the game plan for wheel size? My 18x12 +20 wheels look like they will rub the inside wheel well, and I'm having a hard time making them clear my RLCA's. I may have to run a +5-+10 spacer.
            Not quite. Both front and rear have a 1/2" lip. Not including the lip the rear is +70mm and the front is +40.
            Not prob Mike. Glad to help. Let me know how it turns out.
              They are listed as +70mm but have a 1/2" lip.
                Totally agree about me now needing longer lower control arms, which is another reason can't wait till you make a batch of your RLCA's! For the front was thinking about running stock S14 FLCA until SPL releases theirs next yr. Do you know how much longer the S14 FLCA is than the S13? I have a set of SPL outer tie rods ends to adjust bump steer. Need to get the control arms sorted before I mess with bump steer.
                  I'll be running 275mm tires square. The car will weigh ~2650-2700lbs with the new engine/trans combo. Because of the light weight any wider tires in the front and it will be difficult to get enough heat in the tires to get my quick lap in the first two laps. It's critical to get your fast lap in the first couple laps when competing in the faster classes because after 2-3 laps you start catching slower traffic.
                  The wheels I got are Forgestar F14 18x10 +16. I'll be running 255/35R18 Hoosiers, which are as wide as the 275 Hoosiers. So much so NASA treats this specific tire as a 275. In the photo above there is a 16mm spacer so eff offset is 0. Once I get the fender flares installed and a tire for a fit try, I'll determine the proper spacer width to fill the flares. In order to have full compression w/o hitting the flare I'm thinking I'll need ~20mm spacer. At -4mm eff offset and a 275 wide tire, there is plenty of room on wheel well side. In the front I need min 16mm spacer so the tire doesn't contact the spring.
                  At some pt, I do need to ask you a few questions about how you cut and prepared the rear sheet metal for the flares.
                    A friend of mine bought some parts-store S14 FLCAs thinking they've be longer on his S13, and they turned out to be the same length. It could have been a mistake on the part of the supplier I guess.
                    We're also extending the FLCAs on our ChumpCar build, in order to get more camber gain and raise the instant centers a bit. We have more fender-room to work with as we're only running 15x8s though.
                    Flatout Racing
                    #23 Z32 Chumpcar
                      Awesome, looking forward to this.
                      how come you're not running wider wheels? I know the recommended wheel widths only go to 10... but the smaller 275 goes to 11" :
                      '81 BMW R65
                        that flare is so subtle.
                          The 11" wheel doesn't increase the contact patch enough with a 275mm tire to offset the additional weight. Plus with the 11" wheel, I'd need to run 7mm more spacer. I'm already needing ~20-25mm spacer for the 10" wheels.
                            I'm looking forward to what engine you are going to run to require this wide a tire.
                              I never seen a true aftermarket/oe replacement S14 FLCA.
                              They all think S13 & S14 share the same FLCA.
                              Last time I check they were between 7-10mm Longer than S14's.
                              Easiest way to tell a S13 & S14 arm apart is the Knuckle/Tie-Rod Stop.
                              S13:
                              S14:
