Default Pinion vs output shaft angle. How much is too much
  • Default Pinion vs output shaft angle. How much is too much
    So in my project, after finally getting VET, turbo, CAS, etc etc to fit, its now off to the gearbox. On initial measurements, the difference between the pinion and outshaft angle is about 1.2 -
    1.5 degrees. Its independent suspension in the rear, so the diff is isolated from up/down side/side movement. A 1 piece driveshaft ill be used.
    The issue is I cannot physically get the gearbox any higher without some cutting/welding and I am trying to keep the chassis all in one piece.
    Is there a rule of thumb in regards to difference in angle between the pinion and output shaft?? I have read anywhere up to 5 degrees is acceptable, but would like to hear some other opinions or "facts".
    Note: I have seen the below pop up in regards to proper angles
    Why not space your diff down in front slightly instead of raising the trans up?
      That was one option. I am going to get under there and see just how much it can be shimmed
      Will any old thick washer work?? They are fairly large washers last I checked (and not sure if home depot carries any this size)
        Any large washer that contacts all the area on the subframe will work just fine.
          Did you try calling a professional driveshaft and/or U-joint manufacturer? You might be surprised how much information they'll provide. Worth a shot.
