Replacement Z32 Brake Reservoir Cap Needed
  • Replacement Z32 Brake Reservoir Cap Needed
    Would someone be able to point me in the right direction for a replacement BMC reservoir cap? Here's a pic. I've been searching online the last 20 minutes and it's driving me nuts....
    Thank you!
    '97 240SX - S13 SR20DET
    '17 Civic Type R
    '12 MDX - Tow Vehicle
    '04 TSX 6MT - DD
    Yours cracked? Very easy to over tighten them. Marked mine to make sure no one on the team does just that.
    Short of a WTB on zilvia or something, not sure there's much out there. I just went through this in the spring and luckily had one sitting around that I had forgotten about.
      99% sure I have that one I can send you.
        Found the one I have. It's attached to a master cylinder lol.
        What brand master are you using? From the pic it looks like a centric or something similar. I am going through more boxes to see if I have a spare one that's loose.
          Can you not buy this from Nissan as a separate part?
            Originally posted by gills View Post
            Yours cracked? Very easy to over tighten them. Marked mine to make sure no one on the team does just that...
            Thanks for looking. I'm pretty sure you're right about the overtightening since it was weeping a bit at the last event and I may have gone a tad too far. Lesson learned...
            That would be awesome! I'll PM you my info.
            I picked it up at NAPA. I belive you're correct, Centric.
            When I did a Google image search, the OEM part didn't look the same
            '17 Civic Type R
            '04 TSX 6MT - DD
              I'll look when I get home. I have both a Z32 and (I think) a S14 Silvia which should be the same.
              Sent from my Nexus 6P using Tapatalk
                Thanks!
                '17 Civic Type R
                '04 TSX 6MT - DD
