ISIS T25/T28 turbo lines on Spec R T28?
  • ISIS T25/T28 turbo lines on Spec R T28?
    Hi all,
    Hoping someone here can help. I currently have an ISIS T25/T28 hybrid turbo on my S13 Redtop:
    http://www.isisperformance.com/isis-...det-t25-turbo/
    It has the ISIS black turbo lines, too:
    http://www.isisperformance.com/isis-...det-s13-motor/
    Does anyone know if I can use these lines on my T28 Spec R turbo along with a 0.03" ball bearing oil restictor?
    Thanks,
    Andy
    2006 Honda Civic Si
    2004 BMW 330i ZHP
    2002 Porsche 911 C2 cabriolet
    2001 325ci
    1997 M3 coupe
    1997 Accord Wagon
    1994 Corvette 6-spd
    1994 BMW 325is
    1989 240SX Redtop
    I have a problem. :-P
    forgetting all the spec r hybrid blah blah blah
    a t25 or t28 non rigid line set like that should bolt up to any t25/t28 center housing. Assuming the manufacturers used the standard garret threads at each port.
    so in general yes but when you start dealing with cheap chinese turbos nothing is guaranteed.
