S13 alternator wiring?
  • S13 alternator wiring?
    I am looking to use my old KAE alternator on my LS swap and I can't find any info on the wiring for it. The main ground and power are easy, but there are two other wires - one presumably a switched ignition and one for the dummy light. Does anybody know which of the two wires on this plug is the switched ignition wire?
    Simplify, then add lightness.
    Pop off the column cover and take a peek. I'm almost sure the red/white one is it. I think the plain white one is power from the fusebox.
    Originally posted by Matt93SE
      W/R is the one from the "dummy light"
      Its what controls the charging, not actually just a dummy light thing.
      The real question is why the hell are you trying to use a KA alternator on an LS1 ???
      KA Alt 80A, LS1 Alt 145-155A...
      Just the LS1 swap alone already requires more current capability, then account for dual electric fans, you're well past the KA's output, unless this is a severely stripped down car electrical wise.
        Z28 nails it.
          The other one is not switched. It's hot all the time.
            That small White/Red wire controls a lot actually. The KA alt. actually provides a switched ground source to that wire. If you don't wire it up to a switched ground on your LS swap all kinds of bad stuff happens. The battery light will be on as soon as you turn the ignition on and it will stay on. When you turn the ignition to start a few other warning lights and circuits will go nuts and stay on until you disconnect the battery. I chased my own tail for a few days on that one. So long story short, find a switched ground source and splice the white/red wire into it.
            TEAM FAIL RACING
              I have a seat, a steering wheel, and a shifter. No radio, no power anything, manual steering, etc. 80A is more than enough for my car's needs.
              Thanks for the info guys. I will see how my swap harness guy wires up the harness before I start digging any further into things.
                LS1 stock fuse setup alone is:
                30A for injectors and coils
                15A for sensors
                15A for reverse lockout and a few other things.
                Some electric fans at 20-30A
                Headlights
                Wipers
                Taillights
                ETC, makes for the idea of using a KA alternator for some awful reason, a bad idea.
                You're putting forth effort to take a step backwards, this makes no sense.
                  That's interesting, and I do see that you put some effort into dissuading me from my original intention. I had assumed that the stock KA alt would be enough due to having read that there were several semi popular race units available for the LS series engines putting out 45-60A max.
                  Also, It would appear that your potential power draw numbers are a bit optimistic as the stock 98-00 C5 Corvette's alternator is only a 105/110A unit and that is powering a car with a full stereo system, power heated seats, and the like.
                  My main reason for using the KA alternator was that it is light and I have one sitting around that nobody seems to want. Kill two birds with one stone..
                    But how much less/more do your older headlights draw ?
                    Taillights ?
                    Power seats is something that only gets used momentarily, the electrical system doesnt care if its got to catch back up a bit. But when you're combining all of your systems that are likely to, and will be on at the same time, thats what's going to matter, going with something too small is going to end up making other components that benefit from more voltage (injectors, coils, and fuel pump) end up suffering and performance may suffer as a result.
                    We're realistically looking at what ? 3-4 lbs ? Plus the headaches of a different bracket, possibly pulley also, for that ?
                    Trust me, having driven LSx Schassis, and doing enough work on them, just leave it alone and be happy you've got an alternator upgrade.
                    BTW the fuse references were from a 04' GTO, I had them on the top of my head because I'm currently building an S14 with everything factory still in tact on the inside of the car, power accessorys etc, and wanted to make sure not to overload anything on the original electrical system, sure enough the injectors/coils alone have the same fuse as the oem B/R main power wire for the KA's entire engine, leaving the other two 15A fuses needing for power from elsewhere.
                      Sorry to bring this back from the dead, but I know some of you are EE or just very knowledgable about s13 wiring...
                      Are you sure the white and red wire is the dummy light wire that needs to connect to the alternator?
                      I'm looking at the ignition switch side of the plug, and there are five wires:
                      White / red. 12v constant
                      Grey / white. 12v ignition
                      Blue. 12v accessory
                      Grey / green. Starter wire
                      Grey / yellow. Second starter wire
                      I'm using a tundra alternator on a 2j in a usdm s13.
                      I tested the red / white wire and it's got constant power from the battery.
                      On the ignition harness side, the colors change a bit at the plug:
                      12V CONSTANT WIRE
                      WHITE
                      12V IGNITION WIRE
                      BLACK/RED
                      12V ACCESSORY WIRE
                      BLUE
                      STARTER WIRE
                      BLACK/YELLOW
                      SECOND STARTER WIRE
                      BLACK/WHITE
                      Here's a link to ignition pinouts I found:
                      http://alarmsellout.com/support/diag...01989-1998.pdf
                      These pinouts match what I've found on my s13 (1990).
                        I was referring to the W/R wire that's on the lower harness which connects to the Standard Nissan alternators through the 2 pin gray connector.
                        I'll take a look at the tundra charging schematic and then provide more feedback for your exact setup.
                          Thanks z28!
                          Here's a post I made on zilvia in the 2j swap thread:
                          Originally posted by Black R
                          Well with the tundra alternator something is wrong...
                          I wired it up and it runs my 240 pretty well, but won't charge the battery.
                          Wtf am I missing?
                          The wiring is a hack job by the previous owner though, so that's surely suspect.
                          Can anybody tell me which wires from the fuse box I should wire up to the tundra alternator?
                          The plug has four markings on the sticker:
                          IG
                          S
                          M
                          L
                          (In that order, clockwise from top left.)
                          The big stud on one side is I assume charging output to battery?
                          The wire colors are white, blue, black, red.
                          I believe that makes the pinouts like this:
                          IG = white
                          S = blue
                          M = black
                          L = red
                          Here's a diagram I posted previously:
                          From this, I deduced:
                          IG = goes to ignition switch
                          S = goes closest to positive battery terminal (fused)
                          M = B = goes to positive battery harness (fused). It is on the other side of the ignition switch connected to the positive side of the battery, but furthest from it.
                          L = lamp / battery dash light
                          So far, so good?
                          I found the 89-92 240sx wiring diagram in the repair manual that shows three wires on the oem s13 alternator:
                          W = goes to fusible link B
                          2nd W = merges with the other W and then goes to fusible link B
                          W/R = charge indicator bulb
                          B = ground to chassis
                          Here's a post I found on supraforums:
                          The supra 3 pin connector the pins are as follows:
                          1-L-terminal for charging light
                          2-IG-terminal for ignition power
                          3-S-terminal for Alternator sense
                          The Tundra 4 pin connector the pins are as follows:
                          1-S-terminal
                          2-IG-terminal
                          4-L-terminal
                          So pin 1 goes to 4, pin 2 goes to 2 and pin 3 goes to 1. The pin 3 is left vacant so use silicone sealant to fill it (toyota black fipg will work well also)
                          So on my pigtail...
                          IG = white wire = goes to ignition switch (fused) = turns the voltage regulator on - 12v switched
                          S = blue wire = goes closest to battery positive terminal (fused) OR run to ALT fusible link on s13 (it SENSES the battery) - 12v constant
                          M/B = black wire = MAIN alternator output terminal (connected to BATTERY)
                          L = red wire = charge indicator lamp in gauge cluster - Is this needed to complete the charging circuit on s13?
                          Ground = goes to chassis ground
                          Sounds about right?
                            Connect :
                            L- W/R this is found in the lower harness
                            IG- the black/white striped wire at the gray engine to chassis harness connector near the RH headlight.
                            S- connect this to the large white wire in the lower harness that would normally connect to the schassis alternator output.
                            Large stud run a 4AWG wire directly to battery, bonus points for a fuse in here.
                              Thanks again z28!
                              Where in the lower harness would you suggest as the most accessible location to tap in for the w/r and solid white wire?
                              *The wiring in this car has been hacked up pretty good by one of the previous owners (from when it had a twincam), and then again when I paid a local guy to wire up the swap - I'm now cleaning up and fixing it myself.
